DESBLOQUEIO DO MYLINK POR SOFTWARE
Pessoal, já deram uma dica neste ponto aqui da documentação?
http://www.qnx.com/developers/docs/qnxcar2/topic/com.qnx.doc.qnxcar2.gsg/topic/startup_script.html?cp=0_0_8_0
Acredito que seria uma forma de parar o MyLink durenta o boot... e talvez, quem sabe, colocar neste SH para alterar a configuração que tanto precisamos.
Conversando com meu cunhado, formado em computação, e analisando o QNX uma forma de conectar seria usar um adaptador USB-serial conforme descrito abaixo.
About the QNX CAR platform > Getting Started Guide
Getting Ready
Before you can begin working with the QNX CAR application platform, you'll need to install the development software on your host, connect the host to your target, and install the QNX CAR application platform on the target.
1 Installation summary
Setting up your system involves these basic steps:
Install the development software on your host (Windows or Linux). You'll find installation instructions at the QNX Download Center.
2 Set up your target hardware by connecting the power supply and touchscreen. For example, on the PandaBoard, connect one end of the HDMI cable to the touchscreen, then connect the other end (with the HDMI and USB connectors) to the board's HDMI port and to one of its USB ports.
3 Use an Ethernet crossover cable to connect the target so that it's reachable from your host.
4 Use a serial cable (e.g., USB-to-serial converter) to connect your host to the target's RS-232 port.
5 Set up a serial communications tool (e.g., PuTTy) on your host using 11520-8-N-1 settings.
6 Instal the QNX CAR application platform on your target. This involves creating a DOS partition on an SD card, copying the platform's system files to the SD card, inserting the SD card into the target, and then booting the target. You'll find complete instructions at the QNX CAR platform site on Foundry 27:
QNX CAR platform 2.0 RR -- Installation Instructions
Copyright | Community
Exatamente amigo!
Mas também pode ser usado algum dispositivo para fazer um acesso remoto.
Getting Ready
É galera, de nada adiantou a minha reclamação, na primeira tentativa a mulher da Central Chevrolet disse que o desbloqueio é feito em qualquer css, depois que abri a reclamação da css dois dias depois me responderam, que infelizmente não tem como fazer esse desbloqueio, sendo que tem um sistema diferente que é vendido para o Cruze, que inclusive o funcionário da css fez o desbloqueio, mas o cliente teve que assinar um termo de responsabilidade.
Agora tenho que voltar na css para pegar o telefone do fornecedor do mylink para ver se consigo alguma coisa. A vontade foi de falar um monte de !#@&*%$ para o pessoal no telefone, não tem lógica pagar quase 3.500,00 em um aparelho que não lhe permite escolher o que vocé prefere. O engraçado que 2 a pionner e outras são homologadas e não tem essa frescura do bloqueio do video.
Esperando pra ver se alguém consegue esse desbloqueio para Mato Grosso do Sul
Amigo, mas não tem como a concessionária descobrir, só se o proprietário vacilar e levar o mecânico pra dar uma voltinha vendo vídeo, né, porque com o carro parado fica tudo igual. E faz uns 20 dias que fiz o serviço, não notei nada de irregular. Além disso, me deram recibo e NF de serviço, por isso tenho garantia total.
Agora, se formos discutir a questão do fio, eu não fiz esse desbloqueio do fio porque não sou leigo, sou formado em Eletrônica e ADM, por isso sei que o sistema de comunicação no carro usa uma rede de dados CAN (controller area network) que é chamada por padrão da GM de "GMLAN". Caso ocorra qualquer acidente nessa linha de comunicação ou interferências, pode haver até a queima de algum item do carro. Tem vários tutoriais na internet sobre GMLAN, é só querer pesquisar, a única questão é que a maioria (os melhores tutoriais) está em inglês e por isso pouca gente entende.
A GMLAN vai, por exemplo, para itens de segurança, como ABS e AIR BAG.
Por isso que, comparativamente, achei bem mais seguro o desbloqueio que eu fiz, não é nem uma questão de preço.
E só esclarecendo, não fizeram nenhuma alteração no SW ou atualização do meu My Link, continua a mesma versão que instalei na CSS e me garantiram que não terei problemas com atualizações futuras.
Na verdade, o desbloqueio foi feito em um tipo de Setup de serviço, sem mexer no SW, acho até que o correto seria dizer "habilitação no Setup ou na Bios", algo assim.
Mas como já disse anteriormente, fica a critério de cada um, mas se fosse para soltar o fio e colocar uma chave, eu mesmo faria, aí seria grátis né.
Abs.
Bomdia!
Voce poderia passar o contato de onde o serviço foi executado?
Grato
GALERA, ESSE CARA VENDE O ESQUEMA DE DESBLOQUEIO :
produto.mercadolivre.com.br/MLB-544137997-esquema-de-desbloqueio-do-mylink-spin-onix-prisma-cobal-_JM
NAS QUALIFICAÇÕES VISUALISEI UMAS 10 POSITIVAS E SATISFEITAS PELA AQUISIÇÃO DO ESQUEMA, QUE DIGA-SE DE PASSAGEM É ENVIADO POR EMAIL, SEGUNDO O VENDEDOR SÃO FOTOS E MANUAL PASSO A PASSO QUE QUALQUER UM CONSEGUE REALIZAR O DESBLOQUEIO.
PROVAVELMENTE ELE DEVE TER ESSA SENHA!
ESTOU INTERESSADO NO ESQUEMA, ESTA CUSTANDO 100 REAIS, MAS ESTOU TIRANDO AS DÚVIDAS AINDA, ACREDITO QUE VOU ADQUIRIR O ESQUEMA PQ PRECISO DESBLOQUEAR A TELA PARA CÂMERA DE RÉ.
SE OBTER ÊXITO POSTO AQUI O RESULTADO.
é amigo se pagar R$100,00 vai perder dinheiro, olha o que esta escrito no anuncio do meliante:
Funciona assim, ao final do procedimento você fica com um botão (do tipo liga e desliga) em um lugar discreto do carro onde você liga e desliga quando quiser ao ligar você tem a liberação do vídeo em movimento e desligando o aparelho volta ao normal.
esse tem aqui no fórum de graça se você quiser fazer, sempre tem um sabidão no mercadolivre querendo faturar uma grana sobre os outros....
ta aqui de graça pra quem quiser, ah se alguém quiser depositar uma grana pra mim em agradecimento é só falar:
http://clubedoonix.com.br/topic/9947-desbloqueio-comprovado-mylink-fio-contato/
:P
Bom.. pelo visto não é só aqui que o pessoal não lê todas as postagens... No mercado livre tem muita gente que não tá lendo direito os anúncios também.. heheh
Gilberto, Bom dia!
Eu tenho lido sim e compreendo de acordo com o nível de conhecimento que tenho em parte elétrica de veículos (mínimo). Quanto ao tópico desbloqueio por fio eu não havia encontrado, até porque sou novo no fórum amigo!
Pessoal....
Leiam o começo do tópico.....
Existe uma loja em São Paulo que faz o desbloqueio por software.
Eu mesmo fiz e não tive problema algum... não alterou nada no veículo.... serviço 100% e com garantia.
Caso alguém se interesse me mande MP.
OBS: Somente como auxílio....
normalmente nas últimas páginas do post são membros mais novos que postam suas dúvidas.
Procurem no começo para tentar sana-las.
Não sei pq, mas desd q falam em desbloqueio do ML por inferface, me vem uma sensação d q se eu o possuisse ou tivesse a oportuma de mexer numa central dessas, acredito que fuçando um bocado conseguiria entrar na tela de configuração para então ativar a tão desejada função q habilita o vídeo em movimento. Acredito eu q a entrada nesse menu de serviço seja similar a de um celular, tablet, GPS, e tantos outros aparelhinhos eletrônicos q tem tal menu, q GERALMENTE é acessado precionando uma combinação de teclas, ou segurando-a por algum alguns segundos; no caso do ML, já cogitei até alguma cominação junto a ignição, qm sabe até junto ao botão principal. A galera que tem, não custa nada tentar, se der pau, é só levar pra css, ta na garantia msmo. kkkkk
Se eu tivesse algum amigo com o ML q morasse perto, com certeza tentaria...
Sonho meu...rsrsrs
Sonho meu...rsrsrs
A tela em si todos conseguem acessar apertando 10x o canto superiro esquerdo. O problema é que para entrar na próxima tela, existe uma senha que ninguem sabe... e antes que pergunte, já testamos diversas senhas e combinações conforme posts anteriores
aí o amigo quebrou minhas pernas! kkkkkkkkkkk no comments, mas vou dar uma pesquisada na net pra ver se acho algo...
vlw. fort abraço!
Não consegui acessar essa tela...
O amigo já tentou fazer EXATAMENTE o que o colega 'Ratox' descreveu acima?
Pressionar 10 vezes a tela no canto superior esquerdo?
___________________________________________________________________________
Voltando ao assunto da senha da tela, alguém aí já parou pra pensar se cada ML não tem uma sequencia numérica, gerada pelo fabricante, individual e intransferível para outro equipamento, ou seja, cada um tem sua senha e uma não pega no outro?
