solder Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 7 hours ago, ratox said: Solder Hi, thank you for discovering how to enter the development mode. It was a great achievement for sure! I will try to help you. My first question to you: I think I read somewhere you work on a GM dealer is this correct? I'm asking this because I do have a camera installed on my car, Which was setup on my dealer, and I saw how They did. They used the OBDII port and Their software to configure the rear camera. So if you are on the dealer, you have access to such tools correct? Now, if you are not on the dealer, one thing I can do to try to help, is to dump everything I have and upload somewhere so people can try to help to reach on how to unlock the camera. Do you think que can help? No, I do not work at the GM dealer but I do have the GM MDI (Chinese clone, $200) and GDS2 software (cracked, $0) and SPS software (paid for subscription, 3 mo for $275). If anyone here wants details on how to get this, I can give the info. Sure, I am interested in any dumps. :) Citar Link para o comentário Compartilhar em outros sites More sharing options...
GustavoVicentini Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 Ia comprar a interface da faaftech essa semana, porém com a evolução que teve por aqui, vou esperar mais... Tenho interesse de além de desbloquear o video em movimento e camera de ré, também quero colocar tv digital, será que a interface ainda é a melhor opção pra mim? ou também irei conseguir colocar tv sem a interface?! Citar Link para o comentário Compartilhar em outros sites More sharing options...
solder Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 2 hours ago, Speedracer said: Open in DEV mode MODE explorer, make sure that the stick is already connected and has space available. Use a pencil because the tone is more accurate and will not risk you click cut instead of copying when the required window. click 2 times in '' my device '' in the left corner at the top of ce.vá windows screen in '' storage '' and double-click the folder '' system '' will be there, select it with a click. Then click the menu bar in '' edit '' click '' copy ''. Then return the window and find the MD device, this is your flash drive. double-click and when to enter and view your folders with songs, etc, click again on the menu bar in '' edit 'and then click' paste '. Ready, just waiting for the completion of copy. I just do the procedure. I use this http://www.gpspoint.com.br/forum/34-outros/155700-emulador-wince-com-launcher This is for ARM, not MIPS :( Citar Link para o comentário Compartilhar em outros sites More sharing options...
Seufetelli Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 6 horas atrás, Speedracer disse: Se você abrir o windows ce do mylink, e ir em painel de controle, vai ver uma configuração já estabelecida. Acredito que esteja com o DNS, lembro que estava com o IP e a mascara de sub-rede. olhei rapidamente ontem. Arquivo que chama o mylink quando se está no windows ce em anexo. Lembrando que não nos responsabilizamos por uso incorreto ou problemas que venham ocorrer caso os arquivos sejam manipulados da maneira incorreta. BYOMloader.zip so tem o executável nesse zip, tem como você postar todos os arquivos? No meu emulador esse executável não abre! você conseguil abrir? 37 minutos atrás, adellane disse: Pessoal Algumas informações que foram dadas neste clube do Onix que não posso confirmar sua veracidade: 1) Foi informado que depois de entrar no WinCe o pessoal da Ruza teve de estudar bastante os arquivos para poder desbloquear os videos. Este "estudar bastante pode revelar que existem empecilhos no procedimento 2) Eles conseguem desbloquear o video em estacionamentos de encontros de carros sem tirar o Mylink para fora. Eles usam o notebook neste processo. 3) Aconteceu comigo. Um técnico de som em Goiânia disse que sabia a senha do Mylink. Disse também que poderia desbloquear a câmera de ré no Mylink mas se não houvesse confirmação com o aparelho da GM a configuração se perdia depois de desligar o Mylink. Ele disse para mim marcar com ele depois que ele iria trazer o aparelho que é o mesmo usado pela GM. Essa informação 3 está em contradição com a informação 2 ou senão existem dois métodos de desbloqueio: um usa o aparelho e o outro não. Tem que ver com quem desbloqueou! Se ele desbloqueia sem tirar o mylink do carro como liga do cabo no notebook? A questão da programação voltar me parece coerente! se ele no modo explorer entrar somente como leitura, deve ter uma forma de entrar em modo de escrita. Antes da senha tem um poste dum cara que havia informado um .exe que desbloqueava, talvez é um programa que já altera oque tem que alterar, ninguém conseguiu recuperar esse programa não? Citar Link para o comentário Compartilhar em outros sites More sharing options...
weberfern Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 (editado) Peguei um Onix 1.4 LT ha pouco tempo, e como a maioria (se n, sem exagero, todos) fiquei mt decepcionado com a bost@ desse mylink. Parabenizo a todos pelo esforço, começando pelo Navi q iniciou o fórum, e ao Speedracer q vem trazendo descobertas incríveis. Edit: Ok, pessoal, desci ali para ir no mylink e verificar tbm, porém para minha surpresa eu n consegui acessar o dev mode com nenhuma das senhas aqui divulgadas. Digitei as 5 senhas q vi aqui e nada aconteceu. Segue ai foto do sistema Editado Novembro 19, 2015 por weberfern Citar Link para o comentário Compartilhar em outros sites More sharing options...
alexmatos Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 Peguei um Onix 1.4 LT ha pouco tempo, e como a maioria (se n, sem exagero, todos) fiquei mt decepcionado com a bost@ desse mylink. Parabenizo a todos pelo esforço, começando pelo Navi q iniciou o fórum, e ao Speedracer q vem trazendo descobertas incríveis. Edit: Ok, pessoal, desci ali para ir no mylink e verificar tbm, porém para minha surpresa eu n consegui acessar o dev mode com nenhuma das senhas aqui divulgadas. Digitei as 5 senhas q vi aqui e nada aconteceu. Segue ai foto do sistema Amigo, vc deve digitar a senha 20110827 clicar em OK e depois voltar ao menu do MyLink, ir em configurações e a última opção será DevMode desbloqueado. Citar Link para o comentário Compartilhar em outros sites More sharing options...
Mario Godoy Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 Pessoal sobre os arquivos estarem somente como leitura, já tentaram fecha o software do my link para poder editar? ou em propriedades da pasta onde esta o arquivo click com o direito ir em propriedades e desmarcar a opção somente leitura e aplicar ? Citar Link para o comentário Compartilhar em outros sites More sharing options...
fabiomdj Postado Novembro 19, 2015 Compartilhar Postado Novembro 19, 2015 Pessoal, Quem ja conseguiu acessar outro aplicativos pelo note, tem nesse link um task manager pra wince, se funcionar podemos ver quais executáveis estão rodando. http://www.codeproject.com/Articles/30871/Task-Manager-for-Windows-Mobile-and-Windows-CE Citar Link para o comentário Compartilhar em outros sites More sharing options...
weberfern Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 1 hora atrás, alexmatos disse: Amigo, vc deve digitar a senha 20110827 clicar em OK e depois voltar ao menu do MyLink, ir em configurações e a última opção será DevMode desbloqueado. Opa amigão, valeu pelas instruções. Vou tentar. 1 Citar Link para o comentário Compartilhar em outros sites More sharing options...
HMotta Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 NK.exe é o kernel (cérebro do WinCE). Citar Link para o comentário Compartilhar em outros sites More sharing options...
Sergio ricardo silva Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 Em 05/04/2014 08:28:59, Roberto Costa disse: Assim que se fala!!! Tomara que não desista... Boa sorte amigo, estamos na espectativa. bota pra quebrar brother Citar Link para o comentário Compartilhar em outros sites More sharing options...
Fernando35 Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 Alguem ja conseguiu o desbloqueio do video???? Citar Link para o comentário Compartilhar em outros sites More sharing options...
Fabio Vicente Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 Speed e demais, segue arquivos solicitados. O arquivo zipado tem 68MB e como só consigo mandar 15 por aqui, subi ele no Google Drive. Segue o link: https://drive.google.com/file/d/0B7aVcgN0FdXVV29UWm1GdVJoWm8/view?usp=sharing Se precisar de mais alguma informação ou arquivo estamos por aqui. 1 Citar Link para o comentário Compartilhar em outros sites More sharing options...
Speedracer Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 16 horas atrás, solder disse: This is for ARM, not MIPS :( Hello Solder, Have u tried it ? To reprogram the radio for the camera the dealer has to follow these steps: * Access TIS2WEB * Open SPS Programming * Choose the MDI Tool & Replace and Program ECU * Select the car type then connect the tool to the car * Choose Radio – Programming from the list "Normal Option" Then select the appropriate radio option weather it is a nav or non nav unit “ UFV or UFU etc.. “ * Select the appropriate calibrations including the rear view camera from the menu "green check mark appears to the selected ones" * Hit next and you will get a page that will tell what exactly will be programmed then hit yes * This will conclude the reprogramming proccess. I have posted a few months ago. Anyway , i found this guide from GM. I 'm 99% sure that your solution is ''reprogram ECU''. Citar Link para o comentário Compartilhar em outros sites More sharing options...
samuelsd Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 34 minutos atrás, Fabio Marcicano Vicente disse: Speed e demais, segue arquivos solicitados. O arquivo zipado tem 68MB e como só consigo mandar 15 por aqui, subi ele no Google Drive. Segue o link: https://drive.google.com/file/d/0B7aVcgN0FdXVV29UWm1GdVJoWm8/view?usp=sharing Se precisar de mais alguma informação ou arquivo estamos por aqui. Será que ajuda em alguma coisa esses tutorial system\img\BYOM\Bev\Tutorial Citar Link para o comentário Compartilhar em outros sites More sharing options...
Speedracer Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 (editado) 2 horas atrás, Fabio Marcicano Vicente disse: Speed e demais, segue arquivos solicitados. O arquivo zipado tem 68MB e como só consigo mandar 15 por aqui, subi ele no Google Drive. Segue o link: https://drive.google.com/file/d/0B7aVcgN0FdXVV29UWm1GdVJoWm8/view?usp=sharing Se precisar de mais alguma informação ou arquivo estamos por aqui. Muito obrigado, amigo! Grande contribuição para nós! Estou ocupado agora. logo mais tarde vamos dar progresso. Só adianto que, os arquivos que o Fabio postou, tem as respostas que precisamos. Ou seja, os arquivos modificados para a câmera de ré supostamente estarão na pasta SYSTEM, pois se foi dito a ele que se voltasse as configurações de fabrica, ele perderia a configuração feita pela empresa. Sendo assim, isso comprova que o executável postado por um membro de outra comunidade faz a alteração. Estamos mais próximos do que se imagina. A principio sempre quis que alguém que tivesse o mylink desbloqueado via software, e postasse os arquivos, pois assim conseguiríamos descobrir a alteração. Mais uma pergunta, Fabio, você tem o vídeo em movimento desbloqueado também ? Solder ? Have u emulated mylink's software before ? or not yet? Editado Novembro 20, 2015 por Speedracer Citar Link para o comentário Compartilhar em outros sites More sharing options...
Enilson Santos Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 Pessoal, Como a quantidade de informação é grande neste post, principalmente nos últimos dias, alguém teria um resumo de como fazer pra acessar e copiar os arquivos para um pen drive? Citar Link para o comentário Compartilhar em outros sites More sharing options...
Seufetelli Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 Pessoal, Como a quantidade de informação é grande neste post, principalmente nos últimos dias, alguém teria um resumo de como fazer pra acessar e copiar os arquivos para um pen drive? Poderia passar o procedimento e fechar esse post, abrindo outro sobre a modificação!!!???? Citar Link para o comentário Compartilhar em outros sites More sharing options...
Fabio Vicente Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 1 hora atrás, Speedracer disse: Muito obrigado, amigo! Grande contribuição para nós! Estou ocupado agora. logo mais tarde vamos dar progresso. Só adianto que, os arquivos que o Fabio postou, tem as respostas que precisamos. Ou seja, os arquivos modificados para a câmera de ré supostamente estarão na pasta SYSTEM, pois se foi dito a ele que se voltasse as configurações de fabrica, ele perderia a configuração feita pela empresa. Sendo assim, isso comprova que o executável postado por um membro de outra comunidade faz a alteração. Estamos mais próximos do que se imagina. A principio sempre quis que alguém que tivesse o mylink desbloqueado via software, e postasse os arquivos, pois assim conseguiríamos descobrir a alteração. Mais uma pergunta, Fabio, você tem o vídeo em movimento desbloqueado também ? Solder ? Have u emulated mylink's software before ? or not yet? Sim Speed, vídeo em movimento e câmera de ré. Só não tenho a TV digital, pois a maior parte do meu trajeto diário e em estrada e a maior parte não tem sinal digital. 1 Citar Link para o comentário Compartilhar em outros sites More sharing options...
weberfern Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 Bom dia pessoal, alguém poderia postar a foto e descrição de qual é a chave torque utilizada para remover os parafusos e sacar o mylink? Se possível algum link de site de venda. Obrigado. Citar Link para o comentário Compartilhar em outros sites More sharing options...
Maurício Poli Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 22 minutos atrás, weberfern disse: Bom dia pessoal, alguém poderia postar a foto e descrição de qual é a chave torque utilizada para remover os parafusos e sacar o mylink? Se possível algum link de site de venda. Obrigado. Eu uso esse kit: http://www.wabferramentas.com.br/produto/kit-de-ponteiras-para-parafusadeira-com-25-pecas-e-porta-bits-bosch/19054 1 Citar Link para o comentário Compartilhar em outros sites More sharing options...
weberfern Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 2 minutos atrás, Maurício Poli disse: Eu uso esse kit: http://www.wabferramentas.com.br/produto/kit-de-ponteiras-para-parafusadeira-com-25-pecas-e-porta-bits-bosch/19054 Valeu amigo. Citar Link para o comentário Compartilhar em outros sites More sharing options...
Speedracer Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 1 hora atrás, Fabio Marcicano Vicente disse: Sim Speed, vídeo em movimento e câmera de ré. Só não tenho a TV digital, pois a maior parte do meu trajeto diário e em estrada e a maior parte não tem sinal digital. Muito grato pela sua colaboração! E devido a isso estou tendo resultados esclarecedores, graças a sua ajuda. Chequei todo o conteúdo da pasta system e os arquivos não possuem nenhuma alteração. Chequei os 5.519 arquivos e as 503 pastas . Se possível e quando tiver disponibilidade, peço por favor que nos ajude novamente copiando todo o conteúdo da pasta ''NORDATA'', disponibilizando aqui na comunidade. Os arquivos de comando tem grande probabilidade de estarem lá. Muito obrigado mais uma vez e grande abraço por essa força. Citar Link para o comentário Compartilhar em outros sites More sharing options...
HMotta Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 5 horas atrás, Fabio Marcicano Vicente disse: Speed e demais, segue arquivos solicitados. O arquivo zipado tem 68MB e como só consigo mandar 15 por aqui, subi ele no Google Drive. Segue o link: https://drive.google.com/file/d/0B7aVcgN0FdXVV29UWm1GdVJoWm8/view?usp=sharing Se precisar de mais alguma informação ou arquivo estamos por aqui. Sabe nos informar mais ou menos a data em que você desbloqueou o MyLink? Citar Link para o comentário Compartilhar em outros sites More sharing options...
vmeyer Postado Novembro 20, 2015 Compartilhar Postado Novembro 20, 2015 4 horas atrás, Enilson Santos disse: Pessoal, Como a quantidade de informação é grande neste post, principalmente nos últimos dias, alguém teria um resumo de como fazer pra acessar e copiar os arquivos para um pen drive? 3 horas atrás, Seufetelli disse: Poderia passar o procedimento e fechar esse post, abrindo outro sobre a modificação!!!???? O tão esperado desbloqueio está mais perto do que nunca, mas ainda não foi concluído. Vamos continuar acompanhando esse thread, post a post, pois assim cada um pode ser que encontre uma forma de contribuir. PS: Muito obrigado à todos os envolvidos nessa verdadeira redenção do famigerado MyLink. Navi, Speedracer, Solder, Fabio Vicente e tantos outros "soldados anônimos"! 2 Citar Link para o comentário Compartilhar em outros sites More sharing options...
